Antec Performance I P180 Silver Computer Case - HELP
Mattax
Antec Performance I P180 Silver Computer Case - where can I find case filters for this case?
I opened it up today for the first time and it is freaking awesome! Much better than those old cases...
Actually, I think I will need a little more help than just the filters. Anyone with one of these cases...if you can give pointers and tips on set up, that would be great. Obviously, I do not want to get ahead of myself, so only want to install the necessary components first as this is a completely build from scratch set up.
I have the following components as seen in this thread
http://forums.anandtech.com/messageview...atid=27&threadid=1861904&enterthread=y
Those are filters? I was expecting something a little more thicker. Is that the only two places it will be needed? Or should I put filters over the fan inlets to cut down on dust?
? If you're that worried that much about dust, you can tape shut the top blowhole and the grill on the back meant for the VGA duct. The filters for the intakes are more than perfectly adequate...
