I bought a P180B, used AS5 on the X2 4600 and spent several hours on cable management, using it in my Main PC in it (see sig). I'm not overclocking anything.
Here's my idle temps:
CPU: 50c
System: 40c
GPU: 45c
I'm using all three stock Antec 120mm TriCool fans, one at the top back, one at the blowhole and one in the bottom HD/PSU chamber. The top two are set to high and the bottom is set to low (connected to the PSU's "Fan Only" connector). I also installed two 120mm Yate Loons in the removable HD tray in the upper front of the case to help bring cool air in.
FYI I'm in Alabama; the ambient temp is 30c.
I've reseated the heat sink...twice...and the results don't change. I've also touched the CPU heatsink while the computer is on and it doesn't feel hot.
I've heard that it may be my mobo reporting temps that are too high. I doubted this at first but now I'm beginning to agree with it. I've done everything I can, including buying a new, cooler case and spending hours on cable management, and I still have high temps.
FYI I have my PSU's "PSU Fan Monitor" cable connected to my mobo's "CHA1 Fan" connector. Should I try disconnecting it? Also, the mobo's chipset fan and the CPU fan are both connected to their respective mobo fan connections.
Here's a screenshot of SpeedFan (maybe this will help):
http://img208.imageshack.us/img208/4354/speefanef4.jpg
What does the "Core" refer to and why is it so hot?
And here's a shot of my "Freezer":
http://img177.imageshack.us/img177/9130/fanskp5.jpg
What should I do to get these temps down?
CPU: 50c
System: 40c
GPU: 45c
