- Aug 15, 2004
- 536
- 0
- 76
May be some Antec P180 owner can enlighten me on how to remove the fan opposite to the power supply. The fan is attached to a holder which has just 4 clips on it and clips on to the vertical metal frame.
I tried to slide it while pushing the plastic clips IN to the metal (read it somewhere before) but there is no give. I do not want to break it with a scewdriver. I apply a fair amount of force, no dice.
So any idea on how to remove this fan without breaking it or my fingernails?
Thanks,
Thanks,
