H helppls Senior member Jun 19, 2001 216 0 76 Dec 30, 2008 #1 Will a PSU with a top 120mm fan get enough air flow with a p180? Text tHere's a look at the case, the PSU mounts at the very bottom.
videogames101 Diamond Member Aug 24, 2005 6,783 27 91 Dec 30, 2008 #2 You can mount the PSU with either side up or down.
PCTC2 Diamond Member Feb 18, 2007 3,892 33 91 Dec 30, 2008 #3 I Have a P182. They made it so you can mount a PSU w/ a top/bottom fan an have about 1" of clearance for airflow from the bottom chamber.
