Antec P180 Front panel connectors
bgc99
I noticed after hooking up the front panel connectors (pwr, reset etc.) to my mobo (Asus A8N-SLI Premium) that the little connectors seem loose. After they are connected and you move the ribbon cable around, you can see all the little connectors moving around. Just wondering if others had seen this?
Also wondering how you're front audio connectors are working if you used the all-in-one connector?
Thanks,
BGC
Yes the connectors are loosely fitted as they are in my last case as well. This is common. I did not hook up the front I/O audio, but yours should work just fine. 🙂
