Antec P180 Case w/PC Power & Cooling PSU
treskin
20
I have the 750, I think they're the same but just to give you some initial impression - it fits the P180 but is so long (the PSU itself) it requires removing the lower bay fan. Both power cords reach on my eVGA 680i board, which are about as far away from the PSU as possible, but they're both stretched across the board. I'll probably end up getting extensions for better cable management.
treskin
20
You should be able to keep the fan there, you just have to move it to the other side from it's default position.
The PSU was a little bit of a pain to install, but for the rock solid rails and cool performance, it's worth it.
