Can anyone with a P180 case tell me if the TriCool fans that come with it are removable? If so I'd like to replace them, possibly using some of Antec's rubber grommets, but I can't tell if they're permanently attached to the case.
I think all of them except the one on the bottom by the PSU. I'm sure there's a way to get it out but it was a real pain for me to the point where I took the case back.
I have a silverstone PSU that NEEDED that fan to come out and it wouldnt budge 🙁
You can remove them easily. The ones on the bottom and in front sit in a plastic holder where you can just pull out. The top one however may need to be modified as only 1 side is screwed in and the other side kind of sits in a grooved area. I couldn't put a Yate Loon in there because of that.
