For maximum cooling and good air flow, I?m thinking of configuring the case
this way:
Lower Chamber:
Sealed closed as much as possible (duct taping if needed).
2 500GB SATA2 HDDs and Antec TP-II 550 PSU (120mm fan).
Supplied 120mm x 38MM fan in between set on LOW.
Upper Chamber:
Extra front mounted Antec 120mm TriCool fan drawing air in and set to MEDIUM.
- no drives mounted in the upper cage.
Supplied top and upper back 120mm fans set to LOW.
VGA duct removed and opening duct taped over to close it.
Gear involved with heat and noise:
Asus A8N-SLi PREMIUM nForce4 w/Asus AI Cool-pipe (no chipset fan)
2 x 1GB OCZ PC-3200 400MHz Dual Channel EL DDR Titanium
AMD 64 X2 4800+ PIB
BFG GeForce 7800 GTX OC 256MB PCIe
There will be a sound card in the lowest PCI slot, a floppy in the exposed 3.5? bay and a DVD burner in the 5.25? bay area but they shouldn?t bother airflow.
I have no plans to overclock.
I?m looking for quietness, stability and performance in that order.
How noisy is AMD?s stock CPU fan?
I?m reluctant to fool with thermal paste and 3rd party heatsinks.
If easily done, I suppose I could swap CPU fans. (120MM?)
How noisy is this box likely to be?
Any advice/suggestions?
TIA,
this way:
Lower Chamber:
Upper Chamber:
AMD 64 X2 4800+ PIB
TIA,
