Antec One front panel audio problem, no Jack Sensing
twin_suns
4
Hi,
I’m having a problem with the front panel audio with my new Antec One case. While the headphone jack plays sound fine the problem is that it doesn’t detect when headphones
are plugged in and does not mute the rear speakers. Jack Sensing is not working at all and Realtek HD Audio Manger marks both the headphone and mic jack as permanently plugged in.
I’ve tried re-installing the audio drivers many times and can verify that an HD Audio header is plugged into the mobo and not an AC’97.
Could anyone with an Antec One confirm whether or not the front audio panel supports Jack Sensing? If so anyone has any idea’s why mine’s not working? Thanks.
antef
337
I have this exact same problem with a Silverstone PS07. The front jack works but after being used the system does not switch back to rear output. I can't even really choose speaker output myself through the mixer, the setting won't stay. My Audio Manager also always shows the front jacks as permanently plugged in and I'm wondering if this is why switching between outputs doesn't work properly.
