Antec OEM PC Air Cool Case A/C Kit Card Slot Mount Fan Card -$15
ygreenkitty
190
Amazon
Free shipping.
Do a search in electronics for the fan card. I don't know how to get rid of the personal stuff in the link.
Since I cut and pasted it, you should be able to cut and paste the following description and go right to it.
guyver01
22,135
61
The link only goest to their homepage... might wanna modify it.. or give a product number, or something.
Mr.Diggler
621
Here's a link to the product at antec-inc.com (w/picture). I had one of these...they are pretty much useless. Unless you have a pocket of dead air that you can't get circulation in your case to, I wouldn't get one.
PC Air Cool Fan Picture
A better slot fan from antec is the Cyclone Blower in my opinion (still nothing great though.) Scroll down on the above link to see the picture and if you want, buy it from Amazon for $11 shipped.
Cyclone Blower at Amazon
virtuamike
7,845
13
You can also pick these up at Fry's for the same price. Or if you go to a computer show, they usually have them for $10. Not Antec branded, but it's the exact same product. I have one but really not too much use for it. Works ok for AT setups if you don't have a fan other than the PS on the back, but with most new cases it's not needed.
Leo
279
Cyclone sucks too. Buy.com carries exact duplicates under the startech brand. Better bargain if used with coupons.
Here's some of the startech fans that would be more effective for reducing case temperature:
$7.67 for a dual fan 5.25 hd cooler.
<a target=new href="http://www.us.buy.com/retail/product.asp?sku=10224245&amp;loc=101">$4.95 for a 80 mm case fan - 32 cfms
</a>
