I read some of the reviews over at Newegg and noticed that many people say the metal they used for the case is very flimsy. Exactly what do they mean? Is it possible to very easily bend parts of the case if it was dropped and or something fell on top of it?
If you're the type that typically leaves the side panels off, then the case may seem flimsy. If you keep the side panels securely bolted on, then the case is just fine.
