Baasha
I picked up a brand new Antec HCP-1300 from NewEgg and installed it on Friday.
My rig has 4x GTX-Titan SCs (stock clocks/bios for now), CPU @ 4.8Ghz, a bunch of peripheral devices (10 SSDs etc.).
I am using the ASRock Extreme11 Mobo on the 3.20 BIOS.
I actually picked up the Antec HCP-1300 after reading the HardOCP review of it.
The main issue is that the PSU comes with 5 PCI-E connectors (each with 2x 8-pin (6+2) connectors). However, only THREE (3) of these connectors are 8-pin on the side of the PSU (where it plugs in to the PSU). Two of them are 16-pin connectors that span two 12V rails.
So, with 4 GPUs, I am forced to use at least one of these 16-pin connectors spanning 2 12V rails.
Each of the 12V rails is rated up to 50A which is more than enough for the GPUs.
This particular PSU also has a 'weird' 8-pin connector hanging from the 24-pin MoBo connector - something that needs to be connected to the PSU (read NewEgg review section).
Here is the problem:
The computer keeps shutting off and then rebooting automatically when under stress (benchmarks & games).
The connection configuration is as follows:
1.) 12V1 --> 8-pin from MoBo cable; 2x CPU EPS 8-pin
2.) 12V2 --> 1 PCI-E for GPU (8-pin)
3.) 12V3 --> 1 PCI-E for GPU (8-pin)
4.) 12V3 & 12V4 (spanning 2 12V Rails) --> 2 PCI-E for 2 GPUs (2 x 16-pin)
Please see pic for reference:
I also tried 3-Way SLI and a bunch of different combinations - still crashes!
In fact, I just tried 3-Way SLI by using ONLY the three (3) 8-pin PCI-E connectors (removed the 16-pin connectors altogether) on separate rails (12V2, 12V3, 12V4 while connecting the mobo 8-pin, 2x CPU 8-pin, and peripherals to 12V1) and I still got crashes!
Does this mean the PSU is a lemon/dud?
If it can't even run 3-Way properly (without sharing the rails for the GPUs), it most certainly won't run 4-Way SLI.
I used to run the EXACT same setup (4-Way Titans @ 1.212V and OC'd, 3970X @ 4.8Ghz, same 10 SSDs and other peripherals) on an Antec HCP-1200 - it used to run all day without breaking a sweat. Played every game and ran every benchmark without a hiccup!
Really regret selling that HCP-1200!
Would really appreciate any help/advice with this.
