- Oct 20, 2005
- 263
- 0
- 0
I just purchased a Antec SP-350 SmartPower 350 Watt ATX12V v2.0 PSU Power Supply from CompUSA.
The main power supply connector is a 24 pin job; 4 pins can be separated from the main connector. My board (Epox 8RDA+) uses only the 20 pin old style connector.
Upon inspection I discovered that pin 18 (in this diagram the white pin on top toward the right) has no wire leading into or metal connector in pin 18 itself. I understand that pin 18 carries -5Vdc.
Is pin 18 required? Did I get a bad power supply?
