DarkKnight
I just noticed today then when you set the CPU fan to blow air out of the HS, instead of blowing in, my temperatures improved a lot. My idle fell from 50C to 48C and my load fell from 68C to 61C. Not only that but during prime95 my system temp is only 36C instead of being in the mid 40s. My heatsink is Thermalright SLK-900A, system is basically the same as below, except diff motherboard, case, no fan controller. Dont know if it will help everyone because I modded the PSU fan and have a new pci blower, so it exhausts air much better then a stock aria, but if any of u guys are having problems with ur cooling on the Aria, this could help. If any of u have arias, post ur results 🙂
