Antec 900 - Power LED? Speaker?
jgdiablo
Folks,
I'm building my first rig. Although everything is working well so far, I did notice that the Antec 900 manual mentions a Power LED wire, but I don't see such an LED on the front panel, nor the wire. Am I missing something?
Secondly, the case doesn't have a speaker to connect to the Motherboard. Any options to add on?
There's no power led on the front panel, only HDD seek. You should be able to tell that the computer is on by the huge LED's on the front though 🙂
I don't see the point in a speaker on the case. All it does is beep upon posting. You could find a speaker online if you really wanted one though.
Yeah, the LED fans are your power-on light. Shame on Antec leaving off a noise box - cheap barstids!
.bh.
