Hi,
I am building my first build, I need help in connecting the case fan's.
1. Antec 900 comes with four fans. I have a Antec PSU TP3-650 with two "fan only" connections. How do I connect the remaining two fans & other fan that I may add to the side of the case.
2. In the PSU there is blue & black wire (I beleive it is Fan RPM Monitor) where do connect this on the motherboard? In the motherboard there are 3 fan connections(SYS_FAN, SYS_FAN_1 & SYS_FAN_2) one is 4 pin & others are 3 pin. These are the PSU Connections
3. This may be a dumb question, do I connect 4-pin ATX12V to the motherboard and 24-pin ATX12V connection also to the motherboard?
4. The case has IEEE 1394 connection but my MB doesn't have this, how do I make this connection to work, do I have to buy IEEE 1394 card?
Any help is appreciated.
This is my build list:
GA-P35-DS3L/S3L - motherboard
Antec 900 case
Antec TP3-650 PSU
Intel core 2 duo E6750 processor
G-Skills 2GB(2X1GB) DDR2 800 RAM
Radeon HD 2900PRO - Graphics card
Viewsonic 22" HD Monitor
WD 250GB SATA - HD
Samsung 20X DVD SATA
Windows Vista 32-bit home premium
Planning to add another 320gb SATA-HD later..
Thanks.
Antec 900 case
Antec TP3-650 PSU
WD 250GB SATA - HD
Thanks.
