That depends on how many 3-pin fan mounts your motherboard has. If you want to monitor the three front fan mounts then you need at least 4 3-pin fan mounts (1 for the CPU fan, 3 for case fans). However you can't go wrong with getting 4-pin fans since they get power from the power supply.
