Antec -5V issue
SecretAgentMan
I got an Antec 510W PSU from a friend. I hooked it up to my system and everything runs fine, and all the voltages are within about 3%, except the -5V rail, which reads 0V in the BIOS and in Motherboard monitor.
Is it safe to run this PSU in my system like that? I haven't got the gall to open it up and stick a voltmeter on it, even if I did know where to measure. Thoughts?
Yes, that's safe. Intel's new ATX12V Version 1.3 Power Supply Design Guide removed the -5v line so it is no longer required.
You wouldn't have to opwn up the PSU anyway. You could back probe one of the power connectors and check the 5V line that way.
Switching power supplies, such as yours, typically need a load present to regulate voltage properly.
Since the -5v line is not used there is no load present, thus the power supply cannot regulate it properly and it shows 0v via your motherboard's voltage monitors.
The -5v and -12v lines are no longer used. And as a previous poster pointed out the newest ATX revision actually calls for the -5v line to be removed (the -12v should be removed shortly as well).
Thanks for the info.
I was kind of nervous about using it because it looks like someone hacked off some of the wires coming out of the supply and capped them off with heatshrink.
Shoot I just got a new PSU...
In the future will it HURT to have those lines present? I just spent on an Antec 430W truepower
Well future ATX revisions would most likely use a slightly different connector.... So your would ethier be getting a new PSU or is possible using a adapter. Once again the -5v and -12v lines would continue to go unsed. I don't see the source of any harm....
Hmm thats fine then. I wonder how long before there will be a new ATX revision.
