Antec 450W Smart Power PSU question
fibes
833
I just built my brother a computer with the Sonata II case (come w/ the 450w PSU). I noticed on the 12V rails that it ranges at about 12.1-12.2. Is this something I should be concered with? I understand Antec makes quality PSU's, and that's the reason I bought the case, but I never had a PSU exceed 12.0. Any advise would be appreciated.
Thanks! :beer:
Componets:
Antec Sonata II
Chaintech VNF4 Ultra
1GB. G-SKill PC3200 (1 module)
AMD 64 3200+ Venice
128MB Sapphire X800 GTO
120BG WD HD
NEC DVD+R
OdiN
Banned
Mar 1, 2000
16,430
Strange you've never had one go over 12V. Many will. The 12V rail can be +/- 10% of 12V and be within spec. You're okay there.
fibes
833
Thanks Odin. Yes it's true, none of my PSU's have exceeded 12V. On my present computer, I'm running around 11.71-11.85 on my 450W ePower/Tagen.
