Antec 300 Power Button
hoss
42
I've had this case for ages and it's still going strong, with one exception. Recently the power switch was pushed in. I pulled the cover off the case and the switch itself works just fine, but one of the clips that secures it to case front has broker off. Not even sure what to call this black piece of plastic, so hard to see if they are available as a replacement part.
Can anyone help me out? Before I go DIY, I just wanted to see if this a replacement part exists.
UsandThem
16,068
7,383
Just contact Antec customer service. They should be able to send you a replacement part if they still stock it, either for free or for a fee. It does look like from their website store, there might not be many parts available for your particular case, but they would know for sure.
If you still have the piece that fell off, you might be able to super glue / JB Weld it back on to the piece, or epoxy it to the case.
Reactions: hoss
hoss
42
Sounds like good advice. I'll let you know if Antec responds.
techman_hou
I realize this is an old thread. I am looking for that same plastic bezel that supports the main Power switch for my Antec 300 case. I am wondering if OP had any luck in getting one from Antec.
An image of it can be found on this Antec 302 how to change switch page:
http://support.antec.com/support/solutions/articles/1000180311-302-power-reset-button-removal
Let us know. I have an Antec 300 which is very nice but my front panel USB 2.0 ports are spotty now. I'd like to replace them.
Antec at one point in time listed that USB port assembly:
http://store.antec.com/parts/300-front-port-assembly.html
UsandThem
16,068
7,383
You're unlikely to get a response back from them, as this thread was the last time they've logged into the forums (last seen Oct 19, 2016).
But maybe someone else here might have an answer for you/
