Antec 1080 case and Audigy Platinum.. will it fit?
freddysxg
I'm putting together my new rig..
wanted to get the Audigy Platinum.. but this particular Antec case has that door cover thingy..
question is.. will the Audigy Platinum fit in there ok even with the door closed?
would hate to get it and not have it fit! 😱
thanks in advance,
Freddys
I have the chieftec case that's the same thing as the antec one basically, I don't have the platinum drive thingy, but I know what you're talking about. I even looked at one this morning. I just took a drive and saw how far I could take it out and still get the door closed and measured the distance out to be 5/8 or an inch. At that point the drive hits 2 ridges from the air intake on the door (I hope that makes sense)
These probably wont even be close to where the knobs are for the audigy drive, so I would say you're most likely safe.
