Antec 1030b. Any way to put 120mm fans in front and back?
sep
2,553
Why do you want to put 120's in the front and rear? If you must use them then use them on the side and top!
BAMAVOO
41
It is a noise thang :D
I am so sick of hearing 99 fans spinning and spinning and spinning..............................................................Eternity :D
Falloutboy
5,916
size wise yes its smaller but it hold more in it so it doesn't really matter unless your trying to put water cooling into it
screw3d
6,906
Originally posted by: BAMAVOO
Originally posted by: zodder
Get that 3700BQE that you mentioned before. :)
I would, but I hear it is a lot smaller than my 1030b. is that true?
I went from a Chieftec (much similar, if not identical to the 1030b) and the size reduction didn't affected me at all. 2 x120mm fans are much better than 4 x 80mm fans :) Plus the 120mms are undervolted so I can't hear them over my Truepower 430w.
BAMAVOO
41
Damn you guys are going to make me spend money! :D
