- Jun 30, 2004
- 16,864
- 2,183
- 126
Trying to kill two birds with one stone, I posted this lengthy thread the other day. The moderator moved it to the Suggestions forum where it is doomed to die without responses:
https://forums.anandtech.com/thread...c-today-internal-vs-external-cameras.2521528/
So let's skip to the essential question with only essential information. Here's an Amcrest Wi-Fi Indoor Robotic PTZ (pan-tilt-zoom) camera:
https://www.amazon.com/Amcrest-IP2M...7561123&sr=8-1&keywords=amcrest+indoor+camera
You could read the original thread, or I will say that I'm not interested in POE cameras in either Indoor or Outdoor flavors -- not now anyway. But they leave the user with the same feature: he must still manage a single wire between a source or switch and the camera when he installs it. There are few if any outdoor PTZ cams.
I think I can make an indoor cam weatherproof for outdoor use in our mild So-Cal climate here. That is:
1) I can mount it in a perpetually shaded area while still giving full panoramic viewing of an entire patio and hillside;
2) I can keep the camera fairly waterproof without compromising the optical quality with glare or obstruction.
My plan is to use a clear-plastic circular grocery-store cake-box, waterproofing the wired power connection and the cake-box, and mounting the assembly on the bottom of a 2nd-story waterproof deck overlooking a patio. The only drawback might be moisture condensation from the air already sealed in the box.
What do you think? Do you have other ideas? Does it seem feasible?
