Hey all first poster long time lurker here.
Yesterday I bought a used gigabyte ga-z68x-ud3h-b3 From Craigslist.
I Put in a core i5 3330 that I had laying around.
Currently the board is setup on a cardboard box. Just the mobo, CPU, and a stick of ram.
The system won't boot. the cpu fan spins and the system turns off after about 10 seconds. No image on the screen. The cpu does get hot when it is on. The speaker doesn't beep or make any sounds unless I try and boot without any ram installed. I have tried a different power supply but it only has a 4 pin cpu plug where my mobo needs 8. So I plugged it in anyways as I've read elsewhere it should still work and still the problem persists.
So what do you guys think? Bad PSU or Bad Mobo?
PS: For what it's worth the Craigslist seller said it was 100% working and is confident enough that it is to offer me a refund.
