Originally posted by: mobobuff
You have DirecTV, which means you either have a D10, D11, H20 or R15 receiver. Not any dish will work. The dish would need to use an LNB capable of receiving broadcast from satellite 101º (at least). This is the satellite that DirecTV uses to transmit receiver configuration data and channel guide info. Without communication to that satellite your receiver will not show you anything. Your best bet is to find a DirecTV compatible Philips or WNC dish (any dish DirecTV has used in the last 6 years).
This dish is the triple-sat oval model DirecTV currently uses. It's probably very similar to the dish you have now, if you don't have a KA/KU dish (the larger + wider dish that uses 5 LNBs). Your best bet would be to get ahold of a DirecTV triple-sat dish like the one above. If you lived anywhere near me, I have 4 or 5 just sitting around that I could give you, along with the mounting hardware if you wanted to mount it to something.
If you plan on doing this often, I would recommend getting a
signal meter to make installation MUCH easier. All you need is a $6 metal fence post from Home Depot. They are 1 5/8" outside-diameter. Idealy you would use quik-rete, but you could get away with just pounding the pole a good 2 feet into the ground. Use a level to make sure it's perfectly perpendicular to the ground.
Let me know if you have any other questions.
