Another question I had:
I was looking around and I was wondering if this setup would be better (more silent) to cool the Ti4200?
Install this:
1) Zalman 92mm Fan with Zalman Bracket - ZM-F2 with BR123 Link
Model # FB123
and have it blowing over the video card and unplug the fan on the BlueOrb
or
2) Zalman 92mm Fan with Zalman Bracket - ZM-F2 with BR123 Link
Model # FB123
With this installed Thermaltake Cooler and also unplug the fan and remove that plastic window.
Basically using the Zalman fan to blow air over the Heat Sink thats installed (either a passive Blue Orb or the Thermaltake HS). I would be using the voltage limiter to lower the fan speed (comes with the zalman).
What do you think?
Install this:
Model # FB123
or
Model # FB123
What do you think?
