First, I want to say that I have searched on this subject. I have found some information, but nothing precise enough to eliminate, in the end, what I would call ?wishful guessing? about total power requirement.
I have an Antec SmartPower 2.0 Power Supply rated at 350 watts. Specs are HERE. I am not going to replace this PSU. I want to add a video card, and this card will be selected according to the power the PSU can provide, not the other way around.
This PSU has 10A on the first +12V rail and +15A on the second +12V rail. My system description is in my sig below. System currently runs on NVidia 6150 integrated graphics and comprises:
--- 3700+ A64 Processor
--- 2 sticks of memory
--- 3 HD's
--- 1 DVD burner
--- 1 diskette
What I would like to do is compute the power I have available for an add-on graphics card. It has to be NVidia (same drivers as integrated graphics), and I am thinking about 7600GT or 7900GS. I have seen in recent reviews that the 7900GS consumes a peak of 82 watts according to NVidia . So if I divide this by 12 volts, I get a requirement of just under 7 amps...Right?
I have used the Extreme PSU Calculator, using the 7900GT as an example, as the 7900GS is not yet listed, but should have similar power requirements. The result is a CPU recommendation of 293 Watts. Although my total power seems sufficient, the Calculator leaves questions unanswered, concerning the fact that my PSU has relatively low power on each of its +12V rails.
So I might be alright, but the dual +12V rails confuse me. How can I know what is already feeding off one rail or the other? Looking at the PSU, I don?t see any ?rails?. All I see is a bunch of power connectors coming out of the PSU, the 24-pin mobo connector, the 4-pin mobo connector for the processor and a PCI-E connector. It is my understanding that the PCI-E slot (75 Watts) feeds off the mobo. I have no way to find out what is feeding off one ?rail? or the other. I don?t even know if I have to worry or not about overloading a rail.
Also, what components are using 5V and 3.3V ?
I would like to be able to compute the total +12V power draw of my components, and compare it with total +12V power available from my PSU. I have almost done this with the Calculator, but uncertainties remain: I would like to know if I have to worry about the split between the two +12V rails of this power requirement?And if I do, how do I make sure that I stay within each rail?s power capability.
If my PSU is too weak for a 7900GS, I will get a 7600GT. And if the 7600GT is bordeline, I will get a 7600GS. I am only a casual gamer, but would still like to get as good a video card as my PSU will allow.
Thanks for your comments.
--- 3 HD's
--- 1 DVD burner
--- 1 diskette
