- Jan 4, 2001
- 41,596
- 20
- 81
This is another bizarre story. Same CPU, same heatsink, different motherboards, different temperatures.
I transferred a 750@933 T-bird at 1.85 volts from my Epox 8KTA3 motherboard to a Soltek SL-75KAV. All voltages are the same; the speed is the same; both have arctic silver, both are using the same heatsink and are running the same rpms. The differences:
- On the Epox, the surrounding temp was 30C, but the processor temp was 43C
- On the Soltek, the surrounding temp is 23C, but the processor temp is 56C.
The heatsink is not off center either; I tested for that by applying light pressure to each corner. All resulted in a sudden temperature spike, even reaching 74C briefly. (not even a lockup at that temp)
What the heck gives here? I don't think motherboard monitor is reading wrong, because the BIOS reports similar numbers, plus the heatsink feels quite in line with MBM's reported temp.
