Raswan
So I'm toying with the idea of adding adding a couple of monitors in order to achieve an eyefinity setup, and I want to make sure I understand how xfire works with what hardware I've got. I don't have an unlimited budget, but I'm willing to spend some money.
Current setup:
Gigabyte P55A-UD3 rev 2.0
i5-760 stock
Sapphire 5870 1GB
Gskill 1333 RAM 16GB
Asus VE278Q 27-inch 2ms monitor
1. From what I can gather, the motherboard absolutely supports xfire. From Gigabyte's support site:
1 x PCI Express x16 slot, running at x16 (PCIEX16) (The PCIEX16 slot conforms to PCI Express 2.0 standard.)
1 x PCI Express x16 slot, running at x4 (PCIEX4)
2 x PCI Express x1 slots
3 x PCI slots
2. Yet Gigabyte's website notes that, "When SATA3 / USB 3.0 (Marvell 9128 /NEC USB 3.0 Controllers) work at turbo mode, 1st PCIE x16 will work at x8 speed." I don't know what engages the "turbo mode," but am using the SATA slots.
(Preliminary question: is my 5870 hamstrung right now @x8 by my sata/usb 3.0 usage and I don't even know it? This is something I need to know like right now.)
3. So, my initial plan was to grab two more of those Asus 27-inchers, flip them vertically, and go nuts at whatever resolution would look sweetest (5760x?). In order to do this, I see three options: either I need another 5870, two of something else, or, alternatively, a single-card solution (don't know that there is anything capable of this--the 7970 maybe? I'm a little out on the gpu literature of the last 6 months, having upgraded a year and a half ago).
Does my mobo support a reasonable xfire setup, or are the limitations of that second PCI-E slot going to kill me? If not, what would be the best of the three options above (I realize I'll have to get the 5870 used from someone)? Is this all a pipe dream?
Thanks guys. I really appreciate the help in wading through all of this.
Current setup:
i5-760 stock
Sapphire 5870 1GB
3 x PCI slots
