Another Linear Algebra Proof
ChineseGuy
332
Here is another one for you smart people.
For an invertible matrix A, A and A-1 (<-- that's A inverse) have the same eigenvectors.
I am not sure where to start on this.
Thanks in advance.
esun
2,214
An eigenvector of a matrix A is a vector v such that
Av = cv
Where c is a constant (c is usually lambda, but for the sake of formatting on the forums I'm going to use c).
If A is invertible, that means we can write (I'm going to use A' to be A^-1, again for ease of formatting)
A'Av = A'cv (multiply by A' on the left side)
Iv = cA'v (scalars and vectors commute; A'A = I; also note that Iv = v)
A'v = 1/c v
A'v = kv, where k = 1/c
Therefore A and A' have the same eigenvectors, but the eigenvalues are inverted.
Biftheunderstudy
375
Oh, but that brings back memories of Quantum Mechanics, Simultaneously Diagonalizable matrices, commuting observables.......
ChineseGuy
332
Another question for you guys... What book did you guys used? The text I am currently using is printed in like 1989... And its soo hard to follow. I am thinking of getting another linear algebra book to use as reference.
imported_Seer
309
While we're on the subject...did any of yall ever use Paul Foerster's textbooks in HS? For Agebra 1 and 2, pre cal, and cal? Just wondering.
randumb
2,324
Linear Algebra Done Right - Sheldon Axler
This book is excellent; the exposition is clear and the proofs are clean. However, it does omit some topics like dual spaces, quotient spaces, and tensor products.
mrkun
2,177
I have a friend who thinks that Tom Apostol is the best math textbook writer in the history of human civilization. He has a Linear Algebra text.
Edit: I used Elementary Linear Algebra by Howard Anton and it was tolerable, although I'm sure better texts exist.
