After having dealt with the initial firmware/driver problems through updating with the Copperhead software, my Habu seemed to run well.
Yesterday though i noticed, that every time i start up XP, the standard HID driver is loaded and NOT the Habu's, which results in lower polling rate (125KHz instead of 1MHz) and the Habu mouse not being recognized in its software.
When i unplug the Habu und plug it back in the same USB port, the correct driver is loaded, everything works fine...
How can i bring XP to load the correct driver at startup? Is this rather a Habu or a XP problem?
They should really work thoses issues out at MS/Razer finally...
Thanks
Chris
Thanks
Chris
