I need to make a floppy for a memory diagnostic but when I go to format the floppy the light turns on and nothing happens, the drive just hangs. Is the drive dead?
Most of the dead fds I've seen are Mitsumis. Have had good luck NEC and Sony (have probably used 30-40 of each). Once had a batch of HP pulls (Alps Elec.) that were all very good.
