My TBird runs idle between 35° - 39° Celsius. After heavy duty, it reaches 52° - 56° C.
Some people I know and many of you in this forum, acording to your postings, don´t get such high temperatures, although they have the same CPU/Mainboard/Cooler configuration. I know, 56°C is nothing to worry about, but I´m confused why most of the other Durons/Tbirds with the same configuration run 10° or more below my numbers. I´m sure I´ve mounted the HS/fan correctly, and I´ve also put some thermal compound between the CPU/HS.
I´ve heard the thermal sensor on the ABIT KT7 might show lower numbers, if it was put too far away from the CPU during mounting.
Or does each Athlon reach different temperatures anyway?
Anyone an idea??
Anyone an idea??
