- Apr 16, 2009
- 1
- 0
- 0
Hey all...I know there are like a million of these, but I was curious if anyone has encountered this in the past.
I just built a friend a new PC. We got everything hooked up, and tried to turn it on. The case light flickered on for a fraction of a second, and some of the fans flickered where they got juice for a fraction of a second, so they did a few slow but full rotations. After this happens we get nothing. Flicking the power switch does nothing. The only time I can get it to do the same thing is if I unplug the power supply for about 20 seconds and plug it back in.
I have tried undoing, then reconnecting everything, and I get the same result. Checked there were no screws touching the board that would cause it to short...that was clean. Unhooked the second and third hard drive as well as the optical, same result. I used the power supply in a PC for about a month and never had any problems with it...so I don't think the PSU is the issue.
I am assuming I have a dead motherboard, but if anyone has seen this behavior before and has some guidance, I would be very appreciative. Thanks!
