Yeah, if they have a free airport shuttle, why not? Though the smaller places can be quite a pain to get a hold of sometimes, once stood for 1.5hrs for the shuttle while seeing countless Hertz/Budget/etc shuttles go by.
If the shuttle is free, then go for it. Most times it's jsut more convenient to rent from the airport because you are right there and don't have to worry about then getting to the airport from wherever the rental place is. But I've never found it where the airport ones were more expensive. You might just need to do some emore checking aroudn or find some coupons.
