- Oct 10, 2000
- 2,689
- 0
- 0
Here's the problem with this little booger - The car idles at at VERY high 2000-3000 when it starting up from cold. After about 2 minutes at that rpm, if I step on the gas it would drop down to about 1500. If it drops to around 1000 rpm, the engine would bob up and down between 1000-2000 until I feed the gas a little.
After it warms up to normal driving temperature, the engine idles at about 1300RPM and the pulsating between 1000-2000 stops.
Steps I have done in trying to resolve this problem (and normal maintanance):
1. Changed timing belt, water pump, oil pump, tensioner.
2. Changed spark plugs and spark plug wires.
3. Changed air filter.
4. Adjusted the idle speed screw.
5. Changed radiator and hoses.
6. Adjusted distributor.
7. Changed power steering belt, A/C belt, and alternator belt.
8. Changed oil pan gasket/oil/oil filter.
9. Changed transmission fluid.
Item #4 doesn't seem to do anything to the idle speed (or maybe I am not turning it enough even though I turned it one full rotation).
Adjusting item #6 has a drastic impact on whether the engine bobs up and down between rpms. Advancing the timing via the distributor fully clockwise causes the engine to slowly idle down to about 1300. Changing the timing the other way (counterclockwise) causes the engine to run very roughly (causes it to bounce between those two rpms).
I have also checked the carburator (sp?) and the throttle plate is FULLY wide open with no foot on the pedal and this seems a bit odd to me. Also, one of the vacuum hoses has been cut off and has a screw in place of it. My dad says the mechanic did that in order to pass a smog check?
Now, my question is how do I get the idle speed down to about 850-950rpm while in DRIVE? Also, why does my engine idle at a whopping 3000rpm with a cold start?
I will paypal $5 to the person(s) who suggests a working solution to each question!
