Another build that needs advice!
Alright I know you guys don't need another one, but hey it's fun right?
I'm spending my christmas money on a new compy, cause it's been 3 years and I want to do it right soo...check this out...
Processor: I want dual core and the 3800+ is the lowest and seemingly most reasonably priced. If i can save a bunch of money and go single core and not lose a bunch of performance let me know, but i love doing ten things at once, and definitely forsee making use of that power. Is the 4200+ worth an extra 80$ or so?
Video Card: I want it to rock now and last a while so the 7800GT from eVGa for 299$ seemed like a great price and I know it's a kick ass card. I much favor nvidia, i'm pretty sure about this one, is there anything i'm missing?
Motherboard: I could use some help here, I'd love to spend about 100$ and I certainly dont NEED SLI. That does not seem like an upgrade path for the future in my opinion. I am looking at the Gigabyte - GA-K8N Pro , i'd love to get the nForce 4 chipset, for no other reason than I like (trust) nvidia.
Harddrive: I picked out the WD Caviar SE 16 WD3200ks, 320gigs and it's SATA 3.0g/s sounds fast and big, 155$ not a huge worry for me, just one question how can i make sure i get fast performance, will a normal SATA mobo ensure me the 3.0g/sec? Aagain, the HD is not a big deal, but let me know if theres a screamin deal...
Case: I was just bumbling around and saw this: COOLER MASTER Ammo 533 RC-533-SWN1 Black/Silver Aluminum+Plastic front bezel; SECC chassis ATX Mid Tower Computer Case - Retail - I think it looks wicked, anyone had any problems with it?
That leaves the power supply and ram? I've been building my own computers for years and Ram has always just kinda baffled me. I know that the lower timings are better but is it worth an extra 100$? I want 2 gigs of nice ram, but i can't see paying too much more than like 150-200max is that...possible? any reccomendations?
Powersupplies used to be just psh...whatever you get you throw together, whatever you have laying around or from an old computer, but now it's like a huge deal to get a nice one, and it's just important. I really dont know anything other than i want like 450 watts or more..and that you can spend a bunch of money if you want to. It makes me cringe to think about spending 100$ on a power supply but i guess if that's how you do it these days I want to make sure all my other expensive hardware is getting what it needs. So, i just need reccomendations, i dont need fancy, i just want pure reliability for as little money as possible.
That was a long post and i appreciate you enduring another "this build" post. Thanks in advance for any helpful reccomendations.
-Chris
Processor: I'd definately go dual core, you may want to spend a little extra cash for an Opteron 170, and OC it. Most people can get 4800+ speeds or above with stock cooling on these Opteron CPU's
Video Card: Good Choice, If I was in the market for a new vid card today, that is the one I would buy as well.
Motherboard: That Gigabyte board is not bad at all.. You may also want to look into an ASUS non-SLI board like the A8N-E
Hard Drive: That WS Drive is an excelent choice, I'm not sure how much the newly released 400GB WD drive costs, but it is even better performing. Also look into the Seagate 7200.8/9 Line of HDDs
Case: That case is wicked cool looking IMO. I'd go for it. I'm not sure how well cooling is in it, but most modern cases are getting very good at solving airflow problems, and I dont' for see a problem for you. Cases such as the P150, and P180 will also give you good materials for a low noise/vibration setup if that is important to you.
Power Supply: If you have no plans of going SLI, I'd recommend a 480 Watt Power supply from either PC Power & Cooling, Seasonic, Antec, or Fortron. These are good quality PS's that will server you and your future upgrades well. Make sure you get the models with 24 pin ATX Connectors for maximum compatibility with boards of today and tommorrow.
RAM: For the Athlon 64 Platform, memory timings, don't have as much of a performance hit as the P4 chips due to the A64's on die memory controller. Corsair VS (ValueSelect) RAM is a commonly suggested part for those wishing to get 4GB on a budget. G Skill RAM is also quite decent and moderately priced. Either way I don't think you can go wrong, and I don't believe you will feel that you got your extra $100s worth if you invest it into faster RAM... (If you are going to OC, you may want to consider some DDR500, PC4000 RAM however)
get a seasonic s12-430w power supply. its quiet, and good. or, if thats too expensive, get a fortron 450w or 500w. get corsair value, a 7800gt, an X2 3800+ and an EpoX 9NPA+ Ultra motherboard.
