Another budget system help!
Cares
868
My friend wants to build a system about $300. He only needs a motherboard, RAM, and processor. Here are some requirements:
1. Must have an AGP slot since he has a 9800PRO he wants to use.
2. Must be 1GB of ram (I think 2x512MB is the best choice)
Socket 939
Motherboard: GIGABYTE GA-K8NSC - $75
Processor: AMD Athlon 64 3000+ Venice - $146
Memory: Corsair ValueSelect 1GB (2x512MB) - $80
Total: $301 (pretax/shipping)
Socket 754
Motherboard: BIOSTAR NF325-A7 - $57 or Soltek SL-K8AN2E-GR - $75
Processor: Old Newcastle or Sempron???
He basically wants to do some gaming such as WoW, nothing too graphic intense. Is it wise to go the 939 route or go 754 and save a lot more money? Because if I go 754 then I think a Sempron would be good for him, or is Sempron totally crap? Also with 754 you can get cheaper processors/motherboards (not necessarily Sempron). Is dual channel memory a huge improvement? Any opinions? Is there a way to make it cheaper?
shoRunner
2,629
the skt 754 semprons are a great value, especially if overclocking (many get 2.2-2.4+ on air).
but the venice will also be able to overclock, so i'd stay with it. more potential.
Hacp
13,923
There is an oem venice for 115 dolalrs, and a hs/fan would only cost around 10 dollars. Check the hot deals forum.
Cares
868
Would it be better to get a Newcastle or a Sempron if I went the 754 route.
