another algebra problem (linear)
coder1
Ok, here is the equation:
x-3y=0
5x-y=-14
I came up with 3,1
But it appears to be wrong.
Also does anyone know of a math forum where people can discuss algebra.
Thanks
set x=3y and sub into bottom equation
14y = -14
y = -1
x- 3(-1) = 0
x=-3
you probably forgot a negative
-3,-1 works. Maybe you just forgot the negative sign on the 14 in the 2nd equation?
Since it's a system with only 2 equations, you can check my answer by manipulating the first equation to get x=something or y=something, then substituting that into the 2nd equation. Now you have an equation with only 1 variable. Solve for that variable, and then use that value in the first equation to get the value of your other variable. Hopefully this helps and doesn't confuse you too much.....
-Tom
x - 3y = 0
add 3y to both sides
x = 3y
Substitute in the second equation.
5(3y)-y = -14
Multiply
15y-y = -14
14y = -14
y = -1
Then use -1 in the original problem
x-3(-1) = 0
Multiply
x+3 = 0
subtract
x = -3
y = -1, x = -3
hrmm, trying to figure out why I keep getting y=1
After I multiple the coeffeicents I then get
5x-y=-14
5x-15y=0
I then get
-14y=-14
Where am I going wrong?
Thanks again for all of the replies.
5x-y=-14
5x-15y=0
I then get
-14y=-14
5x - y is jsut (5x) - y, it is NOT 5(x-y) . Only the x is multiplied by 5, not the y.
5x-y=-14
5x-15y=0
I then get
-14y=-14
5x - y = -14
5x - 15y = 0
Thus -15y - (-y) = 0 - (-14)
-14y = 14
y = -1
5x-y=-14
5x-15y=0
then get
-14y=-14
-1 - (-15) = 14, not -14
i hate making this kind of errors. so annoying, esp some how the mind is fixated temporarily and can't see the error
Ok here's another one. I feel this has no solution.
x+3y=4
2x+6y=1
I have used the subsitution method as well as multiplying the coefficients. I keep getting a 8=1 or someothing along that line. All the variables cancel each other out.
x+3y=4
2x+6y=1
Yeah, that doesn't seem to work.
x+3y=4
2x+6y=1
Yeah, that doesn't work out.
You can rewrite the equations as follows
3y = -x + 4
6y = -2x + 1
y = -x/3 + 4/3
y = -x/3 + 1/6
Thus the two lines have the same gradient so must be parallel and therefore can't meet.
Interesting. Here's an old one for you to think about:
___
.99 = 1
The proof was provided to me long ago in 10th grade algebra class. I thought it was interesting.
Edit: Note for the less informed, the bar over the 99 means that 9 repeats to infinity.
