I've started to build a new machine based around this motherboard with a 2.0A P4, Radeon 8500, 2 x 256MB crucial DDR ram. However, I had the system running for about 30 mins. when going through the bios settings (hadn't changed anything yet) the machine froze and started emmitting a loud almost continuous beeping noise - beeping for 2-3 seconds accompanied by a flashing power LED. There is then a slight pause and the rapid sequence beeping continues. Switching off at the power supply seems to be the only way to stop it. I was not attempting to overclock and at first boot, it did detect everything correctly it seemed.
I looked at the post earlier with "beep codes" but didn't see anything there about an almost continuous tone - almost like a phone ringing. The Gigabyte web site, manuals (on and off line make no mention of it, noone from Gigabyte support is replying to my e-mail so I don't really have any idea what this is pointing to as an error. As I don't have second P4 or P4 motherboard to check things I've tried to remove/add components to finds out when the beeping stops. I was able to borrow a second P4 compat. power supply and try that - same issue. here's what else I found:
1. CPU, cpu fan, 2 x 256mb ram modules, video card, power supply fan - beeping tone, no post
2. remove, memory one at a time, switching modules in first slot and all else as above - beeping
3. remove all memory - beeping
4. remove video card - beeping
5. remove power supply fan - beeping (only CPU and CPU fan left)
6. try second CPU fan - spins up as before but beeping
7. remove cpu - no beeping
8. add components except cpu - no beeping but fans spin up, memory led on etc
9 add cpu - beeping again
does it sound like the CPU is dead.... that's what I'm thinking. Anyone able to help with other ideas or know what this beeping tone is (award bios)
Thanks for any suggestions
