That frigging annoying red security shield in the icon tray? I want to turn that annoying little thing off, yes I know my firewall is off, Yes I am aware that XP does not see my AV Protection. Now How do I turn you off?
Let's get this one out of the way first. To disable the Windows XP Security Center open the Services MMC:
Press the Windows and R keys > in the resulting window type services.msc > in the resulting window scroll down to Security Center and double-click on it > In the "Startup type:" box use the arrow to scroll down to choose "Disabled" click Apply and reboot, or, click Apply and click the button that says Stop.
