Annoying squeaking sound from razer mouse
Riddleman
346
I?ve had my razer diamondback mouse for 2 days and its starting to make a really annoying squeaking sound when I left click sometimes. I was wondering if anyone else is having this problem, if so what is the solution or should I just get a replacement?
phisrow
1,399
If the widget is that new, you might be best just RMAing. The fix is probably pretty trivial though. I'd bet that if you opened the thing up(screws always hide under the skid feet) you could lubricate, with just a dash of silicone spray, the left mouse button and stop the problem.
See what the terms of the RMA would be, and decide accordingly.
