Annoying Popping sounds on Creative Inspire T6100
prateik.aj
I've the Creative Inspire T6100 5.1 speaker sys. they've making an extremely loud popping sound. Sometimes they won't be popping for hours, but then later on it can start again continuously and its very very annoying. there is nothing nearby any electric appliance nor a light switch..
now i dont think if i can send to buyer for refund or replace i dont think i'm getting any..
any one got any idea to stop this popping sound..
Thank U very much. 🙂 🙂
Sounds like a bad amp/power supply inside the speaker setup. Is it plugged into a surge protector? It could help if you're getting unclean power from the wall.
I agree with Eureka that since the sound isn't originating from the computer, the two most likely causes are dirty power (common in India) and a bad internal amp.
yes Eureka it's plugged in surge protector i think the bad amp/ power supply causing a problem..
thank u for your help Eureka and mfenn
