Well lets see...
For some strange and obscure reason, sometimes my LAN will just drop out and the boxes connected to the LAN will only be able to send and not receive. I've got 4 computers hooked up to a switch of some brand I can't remember now. All use Windows XP. To fix this problem, the computer hooked to the internet must "reset" the network (disable/enable local area connection) for it to function properly. The reset is pretty random, it happens maybe once every 2 to 3 days. Now thats the problem. What i want to know is:
What are the possible variables that could be the cause of this problem?
- CAT5 cables?
- el cheapo network cards?
- crap switch?
- unsupported buggy drivers?
And also if possible would anyone know how to write a script file for the other computers to automatically "reset" the network from their end? It would be pretty hard as the network would be disabled therefore how could you enable it remotely right?
So if anyone could shed any light to this annoying problemo, I will grant them a Greater Wish plus a couple unborn children souls into the deal as well
Tankho!
- CAT5 cables?
- crap switch?
Tankho!
