annoying beep sound
khicon
Hi, I have an old computer that I haven't use in a month. But when I try to turn it on today it have some weird symptoms that doesn't happen b4.
Well, when I turn the comp on, it make this annoying beep beep beep noise and it hang. The screen is black nothing is on. Some of you say it the video card, no it is not. I've check the vid out and it still work. What could the beeping noise be and why my screen is black?
Pls help?
Thank you.
Make sure the RAM is seated properly and works. Make sure your CPU/HSF are seated properly. Make sure there aren't any unseated PCI cards.
