Annihilator Pro Problems
TheJackal14
I just got a Creative Annihilator Pro to replace by TNT2 card which was working just fine. I put the Annihilator in the computer, turn it on, and right away I can tell it doesn't work. Everything was extremely blurry and it was just like static. Even the DOS boot up screens are screwed up. I can't install any drivers because I can't even see Windows. I have an Athlon 600MHz processor on a K7M motherboard. I've heard there were incompatibilities with the K7M and GeForce, but I've also seen benchmarks with the Annihilator Pro on the K7M and it did great. Just looking for any tips, thanks.
TheJackal14
I did try the card on my friend's machine, and it worked. He has a Celeron, but I still don't think it's incompatible with Athlons because of the benchmarks I've seen.
I'd really like it if the card I had now would just work. Any suggestions?
Otherwise, should I just return it?
