I am trying to determine which TV Box to buy (stream netflix and local storage from NAS), based on my research the 2 I am most interested in is the
- MXQ Pro (S905 64-bit)
- MS8 Plus (S812)
However I am having a real hard time comparing them to determine which is the best choice...
- the MS8 Plus is more expensive but it runs an older chipset (s812 instead of s905 64-bit), I find it hard to swallow paying more for older technology unless there is a reason
- I don;t care about 4K but I use it WiFi and the MS8 Plus review tend to indicate it has better WiFi (is this true at all?), I have an old Linksys EA4500 router
- I noticed that Kodi 16 (Jarvis) is in the works, would it work on the MS8 Plus? Would rather buy something that can be upgraded
- Is the extra 1GB of RAM worth it (MS8 Plus)?
As you can see I am trying to do a rationale comparison between the two, of course anything else to consider please let me know 🙂
Of course I am completely open to any other suggestions as well (beside those 2), but for the price vs features they seem like the best bang-for-buck.
One last side-question, I noticed both models are sold by MANY different companies (looking on Amazon), they all seem to be pretty much the same hardware - so the difference is in the loaded software (which honestly who cares - I can reload it manually if needed), so either I take the cheapest or I would much prefer to get that someone has actually used and can confirm works correctly - anyone?
Thanks,
- MS8 Plus (S812)
Thanks,
