android - possible to use ftp via wifi but rest via LTE?
tommo123
when charging i'd like to be able to have es file explorer or whatever share sd card via wifi but i dont want the rest of the data going via wifi but 4g.
i've seen an option (on s7 edge v6.0.1 i think) to never disconnect data even when wifi connected but i doubt it's there to have data routing choices.
you might have to play around with firewall rules to route the correct connections to the correct interface
one quick workaround is to have a firewall block ES Explorer on mobile/LTE access. not sure if it'll work, but you can test
