And another... What would give better sound quality? ECS K7S5A onboard AC97 codec, or SBlive?
DannyBoy
8,820
www.danj.me
Do i need to repeat myself ?
what the heck...
And another... What would give better sound quality? ECS K7S5A onboard AC97 codec, or SBlive 1024?
Bovinicus
3,145
An SBLive! would definitely provide better sound quality. However, if you are buying a new soundcard, then I would go with another option. The Philips Rhythmic/Seismic Edges are cheap and have better sound quality. Hercules makes a few cheap cards like the Muse and the Fortissimo that are good as well. If you just have an SBLive! laying around, definitely use it instead of the onboard audio.
holdencommodore
1,061
SB Live definately....... on the Philips Rythmic Edge/ Seismic Edge, make sure you get either the PSC703 or PSC705......not the PSC702 or PSC704. The 702 and 704 use the old ThunderBird Q3D DSP, which have been taken out of production and driver support cut.
For CD's or MP3's, windows sounds, depending on the quality of your speakers, the AC97 codec may be adequate..... don't expect good gaming quality or DVD from it.
Cheers
Johnbear007
4,570
So you guys think a diamond MX300 or the k7s5a onboard sound is better? MX300 is aureal vortex 2 .. this is on win xp pro
