I'm installing a 24K BTU / 2 ton mini-split in my garage primarily to use the A/C when working out on the hottest days. So, it won't be used that much; probably a couple dozen hours a year. I am unfamiliar with how much the condensers vibrate. Is it really necessary to drill into the slab next to my garage to anchor the condenser? I'm tempted to use these rubber pads and see if they do a good enough job keeping it in place. Is that a reasonable idea or is the condenser probably going to vibrate itself all over without being anchored?
